07-07-2014 04:06 AM
I can't find the specifications of the +5V output (Pin 1 to Pin 2 GND) on the scope cards 9-pole mini DIN connector
07-08-2014 08:11 AM
07-08-2014 09:52 AM - edited 07-08-2014 09:54 AM
The fuse used on the 5V power line in the DIN AUX connector on the 5922 is 1.10A resettable fuse.
I hope this helps!
Edit: Ah, found the answer before I could look it up! 🙂
