Thanks for the additional questions.
1) yes, you can use the config, start, read, clear blocks in the example the same as you use the traditional DAQ VIs
2) the sequence structure resets all boards and internally cycles through reading data from all boards
3) yes - scale the data with the S&V or OAT scaling functions after the read block in a while loop
4) Max Virtual channels are of little value in this one. In the future, this example can be updated to take of Max, when Max catches up with DSA.
Thanks for the reply.
Preston Johnson
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
