cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
conectar compactRIO con un variador atv312 con CanOpen y controlar con labview
Cecesito conectar un variador atv312 con labview utilizando el compactRIO 9636 utilizando el puerto de RS485 ya sea para CanOen o modbus. Para poder observar las variables del variador desde labview
0 kudos
Mensaje 1 de 2
4.491 Vistas
Good  rjavier
I don't understand what the question is about what you need, therefore, here I am attaching two links to see if they are useful to you. If not, could you ask a question to know what to look for and try to solve your problem?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201711
https://www.ni.com/docs/en-US/bundle/ni-industrial-communications-canopen/page/canopenhelp/canopen_h...
Normally the drives must be configured to send the information through the respective ports, so it will not only be necessary to carry out the programming in LabVIEW but at the same time, configure the ATV312 to send the information.
I hope the information provided is useful to you!
0 kudos
Mensaje 2 de 2
4.471 Vistas
