el 06-22-2014 04:21 PM
Cecesito conectar un variador atv312 con labview utilizando el compactRIO 9636 utilizando el puerto de RS485 ya sea para CanOen o modbus. Para poder observar las variables del variador desde labview
el 06-23-2014 03:08 PM - fecha de última edición 02-21-2024 04:15 PM por migration-bot
Good rjavier ,
I don't understand what the question is about what you need, therefore, here I am attaching two links to see if they are useful to you. If not, could you ask a question to know what to look for and try to solve your problem?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201711
Normally the drives must be configured to send the information through the respective ports, so it will not only be necessary to carry out the programming in LabVIEW but at the same time, configure the ATV312 to send the information.
I hope the information provided is useful to you!
