Digital I/O
Create standalone application using different DAQ device
I am building a test machine that boots and powers down motherboards using a USB-6501.  I am connecting a digital output line from the device to the +V pin on the motherboard, then sinking the signal when I want to simulate a "power button push."
I would like to make the line selectable to the user by placing a control on the front panel.
I am developing this application and creating a standalone version with Application Builder.  I am wondering how LabVIEW would interact with a different USB-6501.  As in different name and serial number than the device I am using to develop the application.
Long story short, I built the application and received the attached error.  Is there something special I have to do to control the device/port/line on the front panel?
I'm kind of stuck here and would greatly appreciate any thoughts on the subject.
Aaron M. Baumer
(5,482 Views)
Do you have DAQmx installed on the deployment computer?
Chris
Certified LabVIEW Architect
Certified TestStand Architect
(5,463 Views)
Yes indeed I do.
Aaron M. Baumer
(5,450 Views)
And MAX and did you import the hardware config from the development pc?
(5,446 Views)
I don't believe so.  I'm not really sure what this means, but ti sounds like something that would affect the way my program runs.
How would I go about transferring the hardware configuration from my development pc to the deployment pc?  Is this something i could wrap up in the installer, or does it require extra steps outside of installation?  Thanks!
Aaron M. Baumer
(5,427 Views)
When you create an installer, one of the options is to export the hardware configuration in MAX.
(5,424 Views)
