02-12-2013 06:44 AM
Hi guys,
I want to analyze the logic behind a number of digital lined being fed into my PC. Is there any sample Logic Analyzer vi which I can make use of to figure out these signals?
I am using the PXI-7813R or specifically its FPGA to develope the program.
02-13-2013 05:53 AM
Hi The_Sugarman
What data are you feeding into your PC?
How is this data connected to the PC?
Have you connected some external device to the PXI-7813R which you are then trying to use to read those digital signals with?
If you want to read the digital input to your PXI-7813R then you should take a look at %Program Files (x86)%\National Instruments\LabVIEW 2012\examples\R Series\Basic IO\Digital Line Input which shows how a digital input can be read on your R series card.
Kind Regards
02-18-2013 07:27 AM
Hi Chris,
Thanks for the reply.
I want to feed in a number of seperate digital signals (betweem 4 and 6 seperate lines) from a device that has no controller in it. It is in effect a "dumb" chip that has a memory.
I plan to connect the data through a SCB-68 connector, through the PXI and then to the PC through the MXI card within the PXI.
So far, no, I have not connected any external device. Interestingly, I had to change my plans from the original project I was working with becasue I couldnt read the data from an external device. In the original project, the external device is a smart printer that I have been using to read in the signals from the inkjet cartridges connected to the printer. But thats another project, if you need more info on either, let me know.
