02-15-2013 10:41 AM
I am building a test machine that boots and powers down motherboards using a USB-6501. I am connecting a digital output line from the device to the +V pin on the motherboard, then sinking the signal when I want to simulate a "power button push."
I would like to make the line selectable to the user by placing a control on the front panel.
I am developing this application and creating a standalone version with Application Builder. I am wondering how LabVIEW would interact with a different USB-6501. As in different name and serial number than the device I am using to develop the application.
Long story short, I built the application and received the attached error. Is there something special I have to do to control the device/port/line on the front panel?
I'm kind of stuck here and would greatly appreciate any thoughts on the subject.
02-16-2013 02:30 PM
Do you have DAQmx installed on the deployment computer?
02-17-2013 03:58 PM
Yes indeed I do.
02-17-2013 05:01 PM
02-18-2013 09:04 AM
I don't believe so. I'm not really sure what this means, but ti sounds like something that would affect the way my program runs.
How would I go about transferring the hardware configuration from my development pc to the deployment pc? Is this something i could wrap up in the installer, or does it require extra steps outside of installation? Thanks!
02-18-2013 09:43 AM
When you create an installer, one of the options is to export the hardware configuration in MAX.
