09-02-2014 10:53 AM - edited 09-02-2014 11:11 AM
Hey guys, I'm preparing for my CLD.
Attached is my solution for the Sprinkler Controller example. I worked on it in a few sessions, and spent 3-3.5 hours total.
I am curious to know if you guys think it would pass.
Feel free to hurt my feelings!
Also, if you're studying as well, feel free to borrow anything here!
09-02-2014 11:26 AM
Found a bug that caused a problem when any Timing was set to 0. Fixed.
09-06-2014 06:55 PM
I believe your timer is working backwards for the display. The document states:
"When a zone is being serviced, the following should occur: .... The Timing indicator should display the elapsed time in second"
Yours counts down the remaining time when being serviced.
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
09-06-2014 06:57 PM
Also it states
"The controller must load the Zone Setup Array data from a Comma Separated Value (.csv) file when the VI starts."
For some reason yours only loads the CSV after clicking Start.
09-08-2014 04:08 PM
@Hooovahh wrote:
Also it states
Thanks for the review, Hooovahh.
I definitely messed up those two bits. I think I need to make sure I read a little more clearly next time.
