NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Knight of NI
Knight of NI
tst
Re: LabVIEW Minutiae (that may bite you someday)
I usually use the OpenG 1D array to string VI, which removes the trailing chars.
___________________
Try to take over the world!
Trusted Enthusiast
chilly charly
Re : LabVIEW Minutiae (that may bite you someday)
This was discussed here 5 years ago. Still not reported in the help... :smileysad:
18685i1E85D8A1A9520CFE
Chilly Charly    (aka CC)
         E-List Master - Kudos glutton - Press the yellow button on the left...
Trusted Enthusiast
TCPlomp
Is your number of elements uneven?
Why don't you post a snippet?
Ton
My LabVIEW Ideas
Trusted Enthusiast
tbob
It must be fixed in LV 2009:
18797i783B95D92611864B
- tbob
Inventor of the WORM Global
Knight of NI
Dennis_Knutson
It works in 8.5 and 8.6. I don't have any older versions to test it with.
Trusted Enthusiast
Darin.K
Behavior in LV6i is same as LV9, which is the expected behavior.  Even number of elements, array is unchanged and comparison is false (equal).  Odd number of elements, last element is dumped by decimation/interleaving, comparison is true (not equal).  Empty array returns false (equal).
Trusted Enthusiast
chilly charly
[ Edited ]
OK, Darin and Ton spotted the issue (discussed here in 2005) : with an odd number of elements, the decimate array drops the last element, instead of creating arrays of different lengths. Even if this is the intended behaviour, I still think it is inappropriate.
I was wrong : This is now properly documented in the help (seems I didn't read the help til the end before sending my previous post :smileysad: ... or the french version has not been updated... this was the case in LV 8.2. I have to check the last version).
@Ton
I don't post snippets because LV9 is not installed on the laptop I'm using presently. :smileywink:
Knight of NI
Knight of NI
tst
Re: Re : LabVIEW Minutiae (that may bite you someday)
@Ton
Try using the current version of the CCT (see Ton's signature). It can create snippets in all versions from 7.0 and up and there are even ways of importing those snippets in versions earlier than 2009.
Oh, and it also still has your name in the about screen. If you're not using it, we're going to have to take it off! :smileywink:
___________________
Trusted Enthusiast
chilly charly
tst a écrit :
chilly charly wrote: @Ton : I don't post snippets because LV9 is not installed on the laptop I'm using presently. :smileywink:
Hmmmmm.... sarcasm ...
:smileyvery-happy:
Active Participant
jcarmody
[ Edited ]
tst wrote:
[...] there are even ways of importing those snippets in versions earlier than 2009.
Here's a JKI RCF plug-in to extract snippets from a Block Diagram png.  I've attached an llb that I have in my /project folder that'll do the same thing.  I prefer the plug-in over the library because I, too, love to right-click on stuff.
Jim
CLD
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
