BreakPoint
LabVIEW Minutiae (that may bite you someday)
I usually use the OpenG 1D array to string VI, which removes the trailing chars.
___________________
Try to take over the world!
Message 21 of 131
(14,741 Views)
This was discussed here 5 years ago. Still not reported in the help... 😞
18685i1E85D8A1A9520CFE
Chilly Charly    (aka CC)
         E-List Master - Kudos glutton - Press the yellow button on the left...
Message 22 of 131
(14,731 Views)
Is your number of elements uneven?
Why don't you post a snippet?
Ton
My LabVIEW Ideas
Message 23 of 131
(14,676 Views)
It must be fixed in LV 2009:
18797i783B95D92611864B
- tbob
Inventor of the WORM Global
Message 24 of 131
(14,668 Views)
It works in 8.5 and 8.6. I don't have any older versions to test it with.
Message 25 of 131
(14,666 Views)
Behavior in LV6i is same as LV9, which is the expected behavior.  Even number of elements, array is unchanged and comparison is false (equal).  Odd number of elements, last element is dumped by decimation/interleaving, comparison is true (not equal).  Empty array returns false (equal).
Message 26 of 131
(14,614 Views)
OK, Darin and Ton spotted the issue (discussed here in 2005) : with an odd number of elements, the decimate array drops the last element, instead of creating arrays of different lengths. Even if this is the intended behaviour, I still think it is inappropriate.
I was wrong : This is now properly documented in the help (seems I didn't read the help til the end before sending my previous post 😞 ... or the french version has not been updated... this was the case in LV 8.2. I have to check the last version).
@Ton
I don't post snippets because LV9 is not installed on the laptop I'm using presently. 😉
Message 27 of 131
(14,599 Views)
@Ton
Try using the current version of the CCT (see Ton's signature). It can create snippets in all versions from 7.0 and up and there are even ways of importing those snippets in versions earlier than 2009.
Oh, and it also still has your name in the about screen. If you're not using it, we're going to have to take it off! 😉
___________________
Message 28 of 131
(14,573 Views)
tst a écrit :
chilly charly wrote: @Ton : I don't post snippets because LV9 is not installed on the laptop I'm using presently. 😉
Hmmmmm.... sarcasm ...
Message 29 of 131
(14,561 Views)
@tst wrote:
[...] there are even ways of importing those snippets in versions earlier than 2009.
Here's a JKI RCF plug-in to extract snippets from a Block Diagram png.  I've attached an llb that I have in my /project folder that'll do the same thing.  I prefer the plug-in over the library because I, too, love to right-click on stuff.
Jim
Message 30 of 131
(14,551 Views)
