07-20-2015 05:29 AM
I make a project and I think WSN module and gateway are a good solution for it, but I'm not sure about distance (its over 300 meters). Can I use directional antennas with WSN modules to increase transmission distance?
07-21-2015
09:14 AM
- last edited on
11-17-2025
11:56 AM
by
Content Cleaner
That might work - that's not a supported use and it hasn't been tested so I can't say for sure. WSN nodes are designed to be able to also be used in a router mode, allowing you to extend your network to up to 900 meters out (using 3 nodes, with 2 being used as routers). Designing your network with this in mind is probably the best approach. Take a look at the white paper linked below; it might be helpful for you during your planning stages.
07-24-2015 03:19 AM
Thank you for your answer. It's very useful information about WSN routers, but I think I can't use routers due landscape.
07-24-2015 04:12 AM
Hi scotia,
you cannot cover the distance of 900metres what i think using WSN devices with using 2 routers. its written that only in line of sight it can communicate upto 300 metres (americas) and also theenvironmental conditions effects.
