06-12-2009 08:03 AM
Good Morning folks,
I ran into a problem yesterday, and while I found a work around, maybe some of you can grant me some insight.
I have a type defined enum with maybe 5 or 6 items in it.. and I would like to put those values into an array. Easy enough to make a constant sting array with those values, but it would be nice to be able to turn the enum into an array so that I reduce the chance of typos, and the code is expandable.
How might one do that?
Danke
06-12-2009 08:13 AM
HI Danke,
In non-RT environments you can use teh property node "Strings" to get a list of the string sin the enum.
Under RT you can parse the enum type desciptor to get the strings.
Does that help or is there a challenge beyond that?
Ben
06-12-2009 08:14 AM
You can use the Strings[] property to programmatically get those values in an array.
B
06-12-2009 09:33 AM
I had a similar question previously (you can find it in the User Forums: "How do I print a Typedef containing an ENUM?" . Here is a picture of the solution that I came up with.
Jason
