11-22-2021 01:50 AM - edited 11-22-2021 02:14 AM
I am also on 1.69.2.0, but unfortunately the call uses slashes and backslashes. No renaming of VIs or classes involved...
$ C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe "C:\Labview\hse-db\Source/DB-Engines/DB-SQLite/Init Interface.vi" "C:\Users\admin\AppData\Local\Temp\Fork\staged\Init Interface.vi" -nobdpos -nobdcosm
edit: I was testing without the LVCompare Git Adapter. After I've tried it, I don't see any error message or whatsoever popping up 😕
11-22-2021 01:55 AM - edited 11-22-2021 02:01 AM
It is broken again - short happiness ...
It worked almost two times - until I opened the LabVIEW project again 😣
No: it depends on which file I compare. With standalone VIs it is still working but when the VI is part of a class or uses such dependencies it doesn't work.
11-22-2021 02:26 AM - edited 11-22-2021 03:10 AM
If you are using the LVCompare Git Adapter make sure to add this key to the ini file if you are using LabVIEW 32-bit
lvcomparepath="C:\Program Files (x86)\National Instruments\Shared\LabVIEW Compare\LVCompare.exe"
But I still get the error that the filenames are the same. But the source of the adapter is available so it should be easy to check the filenames and rename if necessary.
Best Regards,
Stefan
12-17-2021 12:24 AM
Quick update: Stefan has implemented a PoC in the LabVIEW Compare Adapter for Git which solves these problems and which was successfully tested by Ludwig. Hopefully, Stefan‘s changes will be integrated back into the Adapter sometime in January when Sean, the maintainer of that tool, is back in the office.
DSH Pragmatic Software Development Workshops (Fab, Steve, Brian and me)
Release Automation Tools for LabVIEW (CI/CD integration with LabVIEW)
HSE Discord Server (Discuss our free and commercial tools and services)
DQMH® (Developer Experience that makes you smile )
12-17-2021 12:46 AM
Thanks Jörg and Stefan for your help. And thanks Stefan for your quick re-programming of the tool. This makes my everyday work much easier!
12-17-2021 02:38 AM
Since it takes very long to get the original example code updated I'll post the modified tool here already.
You have to install the LVCompare Adapter for GIT Extensions which can be found here
Then replace the exe in the folder C:\Program Files (x86)\National Instruments\LVCompare Git Adapter
with the one from the zipfile in attachment.
What this will do is create a renamed copy in the temp folder if both files to compare have the same name.
In the past GIT Fork would name the $REMOTE and $LOCAL different before launching the compare.
But with the newer version they get the same name because they also want to be able to compare folder structures.
But LabVIEW Compare can't handle 2 files with the same name so the only way to workaround was to rename a file.
To setup GIT Fork to work with this adapter follow the instructions on the link above.
Best Regards,
Stefan
08-04-2022 01:44 AM
For those that want to use a shell script instead of a LabVIEW executable checkout this blog post from @Taggart
https://blog.sasworkshops.com/latest-version-of-git-broke-lvcompare/
Best Regards,
Stefan
09-29-2022 08:47 AM
Can you please provide an attachment to the source code for the updated executable?
09-30-2022 07:29 AM - edited 09-30-2022 07:32 AM
10-10-2022 07:15 AM - edited 10-11-2022 04:14 AM
Thank you. The updated LVCompare Git Adapter is working fine. I'm adding builds for 16, 18, 19 and 20.
Did someone manage to configure Fork to work with the shell script from Sam? The external diff tool needs to be an .exe, right?
