VeriStand
Failed to compile the Simulink model due to the NiBusLib.tlc
### Aborted due to an error in the build procedure for model: Battery
Error: File: C:\VeriStand\2017\ModelInterface\tmw\codegen\NiBusLib.tlc Line: 113 Column: 17
The left-hand side of a . operator must be a valid scope identifier
Matlab - 2017a
VeriStand - 2017
(1,921 Views)
Hi Maya24
This error was caused by referencing a parameter inside of another parameter, for example, parameter_array(parameter_scalar).
If it won't help, try to replace the scalar parameter with just a number.
There is no more information from my side, if these 2 solution versions won't work, I suggest contact MathWorks support to see what they are suggesting.
By the way there is a solution post in MathWorks forumtry to go through that post as well, it might be helpful.
Regards)
________
The best way to show appreciation for someone's help is to give them Kudos or mark their response as a solution.
(1,873 Views)
