VXI and VME
Problem using NI GPIB-VXI/B and AXI429 board
I have tried this driver.
The device is now seen by the controller when using the visa explorer from MAX.
But when I call the initialisation function (Ai429Axi_init from the AXI429 driver library provided with the device) I get the visa error code BFFF0067 : "Operation is not supported on this session."
This operation works when I use the USB bustec controller.
Message 11 of 13
(4,878 Views)
I am using LabVIEW 8.2 on Linux Red Hat 2.6.9. I'm having trouble with the Bustec 3020 drivers. I installed the rpm files from the Bustec website, however, when I run LabVIEW the computer freezes....has anyone got the board working with Linux and Labview?
Message 12 of 13
(4,501 Views)
Hello.
If your problem hasn't been solved yet, could you please create another post (because your problem occurs on Linux)?
Thank you very much.
Message 13 of 13
(4,446 Views)
