VXI and VME
Can you use VXI-DIO-128 with NIDAQ-MX?
I have seen that NI no longer supports VXI-DIO-128 in any version later than 6.9.3. Does this mean that it will not run in any newer versions or just that they are no longer providing tech support?
Is there an order in which you need to setup the system to get it to work if it can be done?
Thanks in advance.
(7,026 Views)
Hello cfjohnsn,
The VXI-DIO-128 does not work with NI-DAQmx.  The latest driver it works with is Traditional NI-DAQ 6.9.3
Laura
(7,011 Views)
