USRP Software Radio
a faster way for TDMS-to-Excel conversion?
I am logging my received packets using TDMS blocks, since it is suggested that low-level I/O is the fastest. Since I need the data in Excel formal, after I finish my experiment, I run a small code that uses 'Read from measurement file' and 'Write to measurement file' blocks to convert TDMS to Excel.
This conversion is taking too long, e.g. 15 minutes to port 1 million bits from TDMS to Excel (I am logging packets in their binary form, 1's and 0's).I attached the conversion VI.
I have 2 questions:
1. Does anyone know any faster way for conversion from TDMS into Excel?
2. I need the 'Read from measurement file' block in my conversion code since received packets are logged into TDMS in the form of a single vector, and I need to convert that very long vector into a matrix where each row is one received packet. Is it possible to do logging into TDMS in the form of a matrix, instead of a single vector? This might be slowing down my code a lot.
Thanks!
(6,606 Views)
Accepted by filipfilip
Hi filipfilip,
Have you considered using the TDM Excel Add-In? You could then save the resulting Excel workbook and get the file format you want.
More information can be found here:
http://www.ni.com/white-paper/4906/en/
There's a solution on this forum post too that can let you do this automatically. I don't know how much faster it would be than your current method but I think it would be worth giving it a go.
http://forums.ni.com/t5/LabVIEW/Convert-Import-TDMS-to-Excel/m-p/1088746
I hope that helps, please let me know if you have any questions.
Charlotte N.
(6,583 Views)
Thanks! I see that the Excel table is a single-column one , instead of a matrix. but that can be easily fixed. Thanks once again!
(6,572 Views)
No worries, good luck with the rest of your project!
(6,570 Views)
