Troubleshooting Hardware
RoboRIO 2 unrecoverable error doesn't disappear
We bought a new RoboRIO 2 that arrived late January, to use it this season, but after a match, we turned on our robot, only to see that the RIO had the Status LED blinking constantly. We tried reflashing our RoboRIO with balenaEtcher a couple of times, and nothing worked. We tried with different dongles for the MicroSD, different USB-B cables and we still couldn't see the RoboRIO in the imaging tool.
Someone knows a way to fix this error?
(1,787 Views)
Hi SaVa_dazo, thanks for posting on the forums. I'm Matthew with NI.
Is it continuing to blink the Status constantly?
Have you tried a different SD card?
(1,761 Views)
Other thought, what programming language are you using?
If LabVIEW, are you deploying the code from the project? ("running" the code from robot main.vi won't persist across a reboot).
(1,749 Views)
yes, it's still blinking.
We tried from multiple SD cards, and nothing...
when we connect the RIO to a computer, windows isn't recognizing it.
Also, we're using Java, but we have also used LabVIEW previously on the RIO
(1,733 Views)
One other thing to try is re-flashing the SD card using Raspberry Pi imager: https://docs.wpilib.org/en/stable/docs/zero-to-robot/step-3/roborio2-imaging.html
Also, a few teams have gotten tripped up on which file to provide to the imager. Make sure to navigate down to to the SD images directory.
(1,729 Views)
We tried using both BalenaEtcher and RPI imager with no success.
And yeah, we were using the correct SD file.
(1,721 Views)
I sent you a private message on next steps.
(1,715 Views)
