10-15-2018
04:31 AM
- last edited on
03-14-2019
02:18 PM
by
NIadmin
How can I host a webVI as dashboard in SystemLink server?
I can't seem to find any examples. I did manage to host them in SystemLink cloud using the examples.
A trick where I tried to load the SystemLink cloud hosted webVI in a SystemLink server dashboard's iFrame seems to fail.
Thanks.
10-15-2018 03:50 PM
Hey André,
We have this example which should work to host a Web VI on your SystemLink Server. Let me know if you have any problems following the example.
10-15-2018 03:55 PM - edited 10-15-2018 03:55 PM
Thanks Brandon,
Seeing the example I remember seeing this before, but couldn't find it.
I'll try first tomorrow.
10-16-2018 04:00 AM
I followed the instructions as described, but ran into the following issues after restarting the server:
Error loading privilege definition file for webvi_plugin. The 'name' attribute is invalid - The value 'Almond Dashboard' is invalid according to its datatype 'urn:com:ni:web:privilege:fileNameType' - The Pattern constraint failed. There is an error in XML document (2, 14). Privilege descriptions and defaults will be unavailable. C:\Program Files\National Instruments\Shared\Web Server\conf\htpriv.d\webvi_plugin.xml
10-16-2018 05:04 AM
Hoorah
The webVI shows up in SystemLink and also runs, despite the webserver error posted above.
It has issues, but I'll save that for a different post if I can't solve it myself.
Thanks, although I would still like to resolve the error mentioned in my previous reply.
10-16-2018 06:09 AM
Somehow these errors vanished along the way, I don't know why.
11-12-2018 04:26 PM
This link is broken.
@JoshuaP can you update the link?
11-13-2018 08:27 AM
We moved the template to the official NI GitHub repository.
11-13-2018
08:33 AM
- last edited on
10-19-2025
09:30 PM
by
Content Cleaner
Awesome, thanks Josh.
You may want to update the hyperlink on the getting started page: http://www.ni.com/tutorial/54037/en/
11-13-2018 08:59 AM
Will do, thanks for the heads up!
