SystemLink Forum
How to host a webVI as dashboard in SystemLink server?
How can I host a webVI as dashboard in SystemLink server?
I can't seem to find any examples. I did manage to host them in SystemLink cloud using the examples.
A trick where I tried to load the SystemLink cloud hosted webVI in a SystemLink server dashboard's iFrame seems to fail.
Thanks.
André (CLA, CLED)
Message 1 of 10
(6,748 Views)
Accepted by topic author andre.buurman@carya
Hey André,
We have this example which should work to host a Web VI on your SystemLink Server. Let me know if you have any problems following the example.
Brandon Grey
Certified LabVIEW Architect
Message 2 of 10
(6,735 Views)
Thanks Brandon,
Seeing the example I remember seeing this before, but couldn't find it.
I'll try first tomorrow.
André (CLA, CLED)
Message 3 of 10
(6,730 Views)
I followed the instructions as described, but ran into the following issues after restarting the server:
Error loading privilege definition file for webvi_plugin. The 'name' attribute is invalid - The value 'Almond Dashboard' is invalid according to its datatype 'urn:com:ni:web:privilege:fileNameType' - The Pattern constraint failed. There is an error in XML document (2, 14). Privilege descriptions and defaults will be unavailable.	C:\Program Files\National Instruments\Shared\Web Server\conf\htpriv.d\webvi_plugin.xml
André (CLA, CLED)
Message 4 of 10
(6,717 Views)
Hoorah
The webVI shows up in SystemLink and also runs, despite the webserver error posted above.
It has issues, but I'll save that for a different post if I can't solve it myself.
Thanks, although I would still like to resolve the error mentioned in my previous reply.
André (CLA, CLED)
Message 5 of 10
(6,715 Views)
Somehow these errors vanished along the way, I don't know why.
André (CLA, CLED)
Message 6 of 10
(6,714 Views)
This link is broken.
@JoshuaP can you update the link?
Chase Fearing
Test Engineer, Certified LabVIEW Architect
Message 7 of 10
(6,598 Views)
We moved the template to the official NI GitHub repository.
https://github.com/ni/systemlink-web-interface-template
Message 8 of 10
(6,581 Views)
Awesome, thanks Josh.
You may want to update the hyperlink on the getting started page: http://www.ni.com/tutorial/54037/en/
Chase Fearing
Message 9 of 10
(6,578 Views)
Will do, thanks for the heads up!
Brandon Grey
Message 10 of 10
(6,571 Views)
