02-05-2009 05:20 PM
02-05-2009 05:33 PM
Hi Josh,
In MAX, under Driver Sessions, select "niSwitch" for the Software Module and "Specific Driver" for 'Simulate With'.
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
02-05-2009 06:13 PM
02-06-2009 09:39 AM - edited 02-06-2009 09:42 AM
Hi Josh,
Let's check two more things.
1. Verify the IVI Logical Name.
2. Verify the Driver Setup string.
Hope this helps!
Chad Erickson
Switches Product Support Engineer
NI - USA
02-06-2009 03:03 PM
02-09-2009 11:28 AM
Hi Josh,
1) When you install NI-Switch, an IVI compliance package is also installed. The PXI-2547 has been supported since NI-Switch 3.4.
NI-Switch 3.4
http://joule.ni.com/nidu/cds/view/p/id/278/lang/en
2) Yes. Initialize w/ Options allows you to determine the topology in the options string. Refer to the NI Switches Help or the attached niSwitch Initialize With Options.JPG for additional documentation. To configure the PXI-2547, include the following in the options string:
DriverSetup=topology:2547/8x1 Mux
Let me know if you have further questions!
Chad Erickson
NI - USA
