Switch Hardware and Software
TB Interlock on PXI-2566 documentation
Maybe I'm just not seeing it.  But I cannot find any information on the "TB Interlock" signal that the NI Switch help file shows is on pin 62 of the NI-2566 switch.
I assume that the "TB" translates to Terminal Block.  And I know what interlock switches are used for.  But I would like to find some type of documentation on what I can/might/should do with this signal.
(6,792 Views)
Hi Rich,
You are correct.  There is no information on the TB Interlock signal.  I'll create a KnowledgeBase to prevent any confusion in the future.  I apologize for the inconvenience.
TB Interlock is indeed a terminal block line, designed in as a safety feature. If a terminal block is attached, then the line is pulled low. We do not currently use the feature; it is available for future use.
Note: The TB_Interlock line is pulled up on the PXI motherboard with a 20k resistor.
Hope this helps!
Chad Erickson
Switch Product Support Engineer
NI - USA
Message Edited by Chad PSE on 02-09-2009 09:06 AM
(6,782 Views)
