Switch Hardware and Software
Forced columns in Switch Executive 3.0
I have one SCXI-1127 (4X8) switch and two SCXI-1129 (4X64) switchs in my system.  I have instrumentation connected to the rows of the SCXI-1127.  The columns of the SCXI-1127 are connected to the rows of the SCXI 1129's via hardwires.  For each row of the SCXI-1127 that I try to connect to a unique column of a SCXI-1129, Switch Executive auto-routes through column-0 of the SCXI-1127.  This causes an error when I try to build a route group because I have multiple routes using column-0 of the SCXI-1127.
Is there a way for me to specify which column of the SCXI-1127 gets used when specifying a route?
Thanks in advance.
(6,412 Views)
To better answer your question, what version of NI Switch Executive are you using? Also, please clarify the following statement "for each row of the SCXI-1127 that I try to connect to a unique column on a SCXI-1129, Switch Executive auto-routes through column-0" what steps are you taking to create these connections?
Ali M
(6,400 Views)
I'm using Switch Executive version 3.0.  I solved my problem by reserving for connections the rows and colums connected to the hardwires.  Then I edited the connection routes to avoid conflicts when multiple routes were grouped together.
(6,396 Views)
