Student Projects
myRIO Aquaponics
Overview of what project is:
Aquaponics is a sustainable farming method that combines the techniques of hydroponics (cultivating plants in water)   and aquaculture (raising aquatic animals in tanks) in a symbiotic environment. In an aquaponic system the waste produced by the fish provides the plants the nutrients they need to survive and grow.  Ultimately, aquaponics is a food production system that provides you with pesticide free fruits and vegetables, as well as delicious, high protein fresh water fish. In addition, aquaponics system uses 10% of water used in traditional farming, has small footprint and is ideal for gardening in an urban setting.
In this project, you will learn how to build a small aquaponic system and automate it with myRIO.  You will learn about flow meters, pH, ultrasonic and digital temperature sensors, as well as principles of signal conditioning and closed loop control.
Picture of project:
Video of project:
Parts List:
Item
12 Gal. Fish tank (21"x11.5"x17.5")
Grow bed
Pipes, fittings, valves
Hydroton Grow Rocks (50L)
40-70 GPH Fountain Pump
ATS26454 Tetra Ht55 Submersible Heater
1x TL082 Op-amp
1x 4.75KOhm Resistor
3x 10KOhm Resistor
2x Diodes
Wiring + Connectors
PinPoint pH probe
PING))) Ultrasonic Distance Sensor
FS300 Flowmeter (Hall Effect)
Temperature Sensor - DS18B20
8 Channel Relay Board
myRIO
Wiring Diagram:
Instructions: myRIO Aquaphonics Instructions.docx attached
C or LV?: LabVIEW
Version of LV: 2013
Code: myRIO_Aquaphonics_Code.zip attached
Sunaina K.
Product Marketing Manager for CompactRIO & TSN
Making the intangible, tangible
Comments
bkvamme
Member
Member
on
I am going to use the D18B20 temperature sensor for a different project, and would like to reuse the VIs in this project to interface with the temperature sensors. Is the VI configured to handle multiple temperature sensors on the same wire?
MikhailK
NI Employee (retired)
on
From what I recall, the code was written for one sensor. Also there's a utility for 1-wire devices on LabVIEW tools network:
https://www.ni.com/en/support/downloads/tools-network/download.onewire-utilities.html
Mikhail
RF Toolkits, Product Support Engineer
bkvamme
Member
Member
on
Mikhail,
Thank you very much for your response. I will most certainly have a look at the example for the cRIO.
evilzone
Member
Member
on
Hi,it looks great, i am working in something similar, have you tried with amonia and nitrate testers?.
MikhailK
on
Hi evilzone! I haven't tried those primarily because I wanted to keep the cost of system down. Those would certainly be great additions, especially for balancing the system (optimal ratio of fish to plants).
Mikhail
dannyalharris
Member
Member
on
A big thanks for this great project !
Can I know, how to save the data obtained from the sensors. For example, the data obtained from the temperature sensor for every 1 hour .
Frostfire77
Member
Member
on
Thanks for the project. But the project, can it work without the hardware connection? This is what seems on my version of LabView 2021. The booleans aren't working for me and the debug area shows NaN. How can it be fixed? Reply to me ASAP, please!!!
