01-29-2013 09:49 AM
I'm having a problem with an application I built.
I want to control my tektronix power supply with Signalexpress LE on a host machine.
LabVIEW is not installed on this machine but I have installed LabVIEW run-time.
All others application I built work fine on my host machine.
I barely can't control my power supply on this host machine...
My application is fine because it's working on my development machine.
Is there any software to install on a host machione to make my application work?
Thank you!
Nicocmd
01-30-2013 04:58 PM
Hi nicocmd,
Just to make sure I understand the case. You built a project that communicates with a Tektronix power supply in Signal Express. Now you want to deploy that project to another computer that only has the run-time engine installed? What do you mean by barely can control?
Best Regards,
Alina M
