SignalExpress
sequence acquisition using window
I have a NI USB-6366 device which I'm using with Signal Express 2015. What I'd like to do is the following:
measure current on a shunt resistor while a digital pin outputs high. I want a single measurement in the window during which the digital pin is high. How can i do this?
(7,530 Views)
By single measurement are you referring to non-continuous data(i.e 2 points for every digital high value)? I have not done too much with Signal Express but I think you can acquire the data and then organize it based upon application needs.
https://www.ni.com/docs/en-US/bundle/373873h/resource/373873h.pdf
Best,
-Brian J.
(7,503 Views)
What i mean is the following:
-digital signal goes high
-start acquisition of analog signal
-keep acquiring analog signal
-digital signal goes low
-stop analog acquisition and fetch resulted data
Hopefully it is clear now
(7,498 Views)
Accepted by topic author tudor.popescu
Sounds like you need to set a trigger. Have you looked at the Getting Started Guide? I linked the triggering section in that guide.
https://www.ni.com/docs/en-US/bundle/373873h/resource/373873h.pdf (page 34)
(7,492 Views)
Thank you for pointing me in the right direction. I solved it with 2 analog signals since you can trigger the report feature only on analog signal.
(7,487 Views)
