SignalExpress
how to change value of dt while recordign data
i only recently started using signal express...
i want to be able to change the sampling rate so i can specify how many data points should be recorded per second...
i know that chagning the 'sampling rate' in the 'step setup ------>configuration' window should do what i want...
however, after havng recorded adn transferred the data to an excel sheet... the dt is always equal to 620u...
somehow, changing the 'sampling rate' has no effect on the final set of data recorded on the excel sheet
regards,
Saara
(6,443 Views)
Can you attach your SignalExpress project file, and post back SignalExpress and DAQmx version so that we can have a look at it?
BTW, what is the hardware you use?
(6,438 Views)
I have got a similar question:
I am using SignalExpress for logging data from a fermentation.
So I do not need high sampling rates. It is enough when SE saves every 2 minutes a sample.
But my questions is: Is it possible to set different sampling rates for loging in the protocol on one hand and for displaying the data on the other hand?
Br
(6,336 Views)
I don't think you can achieve that with SignalExpress, but with LabVIEW, just simply set a timer algorithm to sampling, and log data separately.
(6,328 Views)
