SignalExpress
Waveform Generator (PXIe-5413) doesn't work in SignalExpress
I have a Waveform Generator (PXIe-5413) set up on a PXIe-1078 chassis. The problem is that I can not run the waveform generator using SignalExpress, while the other hardware like PXI-6733 and PXIe-4497 works properly.
It should be mentioned that SignalExpress can recognize the waveform generator, and the drivers have been installed. Previously, the operating system was Windows 7 and the waveform generator worked properly; however, since we have upgraded our os to Windows 10, it is not working anymore. Several screenshots of the code, MAX, and the error that appears have been attached.
The error:
ivi_IviFgen Configure Output Enabled.vi<ERR>
IVI: (Hex 0xBFFA0020) Unknown channel or repeated capability name.
<b>Complete call chain:</b>
ivi_subSFGSetExecParams.vi
IVI_SFG_BlockState.vi:12900
Message 1 of 1
(2,295 Views)
