SignalExpress
Save triggered data from 2 modules
I am using SignalExpress (3.0) with USB cDAQ-9172, a NI9203 current and NI9201 voltage module.  After Acquiring data (continuously), I am using a software trigger on the 9203 current signal to analyze and save the triggered data (collected from all 8 channels on 9203).  However, I am not able to save the data from 9201 voltage module?  It looks like the software trigger only accepts a single module input (I think).  As shown in the attachment "trigger Input.jpg" I can only select 1 module as the input for the software trigger (either the current module or the voltage module)
Is there any way to trigger on a single channel and then save data from both modules?
Thanks!
Ryan
(6,670 Views)
Accepted by RyanC
Hey Ryan!
You can actually do all of this in one DAQmx Acquire step.  There is a tab in the Acquire step where you can specify your triggering.  Then there is a recording options tab up at the top where you can choose to save your data when the logging starts to a TDMS file that can be read in excel.
Doug Farrell
Solutions Marketing - Automotive
National Instruments Automotive Solutions
(6,628 Views)
Thank you for the suggestion.  I was using a "Save to ASCII" step to save this as an Excel file.  I have not tried reading TDMS files in Excel before.  This might be the best approach.  I'll have to try this.
Thanks!
(6,622 Views)
