05-27-2010 02:09 PM
I'm trying to create a heater control in LabView SignalExpress 2009 (shown curiously in the Help About as v3.5.0).
It is a simple ramp and soak control algorithm.
Every fifteen minutes, I want to increment the heater setpoint value.
I've tried using a Sweep Function controlling the offset (V) of a Create Analog Signal step. This generates a step function but the sweep runs as-fast-as-possible. I need the swept value to change only once every 15 seconds.
The hardware I am using is the USB-6009. It does not have any counter or clock functions.
Am I out of luck? Is SignalExpress simply unsuitable for real-time-based operations?
I know how to put together what I need in LabView (I have 8.6 available) but there are all kinds of warnings about trying to import clock-relelated VIs into SignalExpress.
Any help would be greatly appreciated.
05-28-2010 04:46 PM
I have tried messing around with the steps you have mentioned, and one thing I noticed that you can use is under the Create Analog Signal step, under execution control you can set the amount of time to delay after you complete the step. If you are using a DC value signal and just sweeping based off the offset, you can set your Sample rate and Block Size as specified, and then adjust the Execution Control to wait before operating the next sweep step.
Let me know if this helps, or if I misunderstood your application. Thank you!
06-01-2010 01:31 PM
Using the post-execution delay after the Create Analog signal is a good idea. However, it does cause other problems.
I've previously used a DAQmx Generate Analog Output (DGAO) step inside the sweep, using its update period to time the sweep.
It was a "dummy" step used only for timing, because I found I could not output my staircase signal through that same DQAO step.
Attached are some screen prints of the configuration windows for a working staircase generator.
I can't figure out how to make this signal into an Analog Output. If I add a DGAO step inside the sweep, it messes up the timing for the staircase waveform (step time becomes a function of the update period of the DGAO step).
If I add a DGAO step outside the sweep, the signal doesn't get generated until all the sweeps is done (on a Run Once).
This is a "Catch-22" situation and I would appreciate help overcoming this problem.
06-01-2010 01:36 PM
The biggest problem with interpreting results is that the Chart display for my staircase function shows the horizontal scale as seconds. I don't know what it is but it is NOT seconds. I thought it might be sweep iterations but that's not always true. It does appear to be some multiple of sweep iterations. I have to use a stopwatch to get the timing on my Run Once operation.
You have to admit it's a little ridiculous to have to use a stopwatch to monitor what are supposed to be sophisticated graphing functions. Does anyone know what that horizontal scale actually represents?
06-01-2010 01:39 PM
06-02-2010 04:27 PM
The time scale looks to be a bug, as it does not take into account the execution delay on the system at all. It is calculating the time based on the sample rate and the block size specified by the Create Analog Signal. So, every 100m on the X scale seems to represent the execution time plus 1.5s post execution delay. Since there are 320 steps, 320 * 1.5s is roughly the time you see measured as the actual time. I will see if this is an actual bug or not, and if it is truly a bug I will post the Corrective Action Request number here for your tracking.
As long as you set the DGAO step to N samples and check the Use Waveform Timing check box, you should not see any timing issues with that step, and you can continue to control the timing using the post execution delay from the Create Analog Signal step.
06-02-2010 05:11 PM
Thanks for the bug check. It's highly misleading, to say the least.
Unfortunately, the USB-6009 that I am using cannot be used in N sample mode nor in Continuous mode. Believe me, that's the first thing I tried. The only way I am allowed to use the DGAO is in "1 sample (On Demand)". Otherwise, on Run, a DAQ Assistant Error shows Property: SampTimingType, You Have Requested: Sample Clock, You Can Select: On Demand. The USB-6008(and 6009) do not have the on-board sample clock for multiple sampling.
It's a real poser.
06-03-2010 02:12 PM
06-03-2010 05:46 PM
06-04-2010 06:05 PM
