SignalExpress
Data acquisition
The goal:
To record one cycle of a fatigue test "10Hz" with 8 strain gauges every "X" cycles over "X" time. We have the process working with SignalExpress using the recording options start/stop + duration. EG: recording every 1 min for 100ms 10 times should be 10 instances of 100ms (1 cycle at 10Hz) Test lasting 10 min.
The Problem:
The SignalExpress record time is random from 100ms up to 1 second. See attached.
Anyone know how to make this stable? We would like to keep the 100ms if possible.
(4,161 Views)
Hi Bruce,
How exactly is the data being recorded? Is someone pressing record roughly every minute, or is Signal Express doing this automatically? Feel free to attach your signal express project so we can take a look at it.
BrandonN
(4,121 Views)
SignalExpress is triggering the recording. Any help would be great, thanks!
<?xml version="1.0" encoding="UTF-8"?>
<ProjectParameters>
<ProjectName>F:\\Signal Express\\Data Logging\\Logging8.doc</ProjectName>
<ExportTime>1&#8260;12&#8260;2018 14:11:13.156</ExportTime>
<ProjectTools><Tool>
<Type>{72346AB1-BE7D-4B77-8D2F-2E529FAE1F1F}</Type>
<ID>{74800C81-A2E0-46E4-B930-C951242B2504}</ID>
<Name>Connection Diagram</Name>
</Tool>
<Tool>
<Type>{9527FFB2-6FDD-41DB-879C-F511010026A1}</Type>
<ID>{98797A90-67A3-4BE4-A193-1BB6DCC2D255}</ID>
<Name>Properties</Name>
</Tool>
<Tool>
<Type>{9696EB52-0805-44B3-8435-DA1C18215E72}</Type>
<ID>{F6D77F0A-500A-4277-B80A-F492CC02F8CB}</ID>
<Name>Project Documentation</Name>
</Tool>
</ProjectTools>
<WorkAreas>
<ActiveWorkArea>Monitor &#8260; Record</ActiveWorkArea>
<WorkArea>
<ID>{AECF723D-FFCE-4F34-B00D-77780E261891}</ID>
<Name>Monitor &#8260; Record</Name>
<Description>Use this work area for performing acquistion, logging, and live analysis.</Description>
<ProcessesLoggedData>False</ProcessesLoggedData>
<Steps>
<Step>
<Name>DAQmx Acquire</Name>
<Description>Analog Input</Description>
<Type>{4BC53017-7D22-4CBF-971F-E7BE5F659D87}</Type>
<ID>{ACBD2D51-F53E-40B6-8C83-B7215EF75B82}</ID>
<PreDelay>0</PreDelay>
<PostDelay>0</PostDelay>
<UpdateRate>0</UpdateRate>
<String>
<Name></Name>
<Val>
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai0]
AI.MeasType = Strain Gage
AI.Strain.Units = Strain
AI.StrainGage.Cfg = Quarter Bridge I
AI.StrainGage.GageFactor = 2
AI.StrainGage.PoissonRatio = 0.29999999999999999
AI.Max = 0.001
AI.Min = -0.001
AI.Bridge.NomResistance = 120
AI.Bridge.InitialVoltage = 0
AI.LeadWireResistance = 0
AI.Excit.src=Internal
AI.Excit.Val = 2
ChanType = Analog Input
PhysicalChanName = cDAQ1Mod6/ai0
AI.Bridge.ShuntCal.GainAdjust = 1.0040177349167618
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai1]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai1
AI.Bridge.ShuntCal.GainAdjust = 1.0043962855373891
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai2]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai2
AI.Bridge.ShuntCal.GainAdjust = 1.0041542133687862
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai3]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai3
AI.Bridge.ShuntCal.GainAdjust = 1.0038015392913282
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai4]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai4
AI.Bridge.ShuntCal.GainAdjust = 1.0043131261049214
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai5]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai5
AI.Bridge.ShuntCal.GainAdjust = 1.0038082613883639
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai6]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai6
AI.Bridge.ShuntCal.GainAdjust = 1.0043200440253051
[DAQmxChannel SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai7]
AI.Max = 0.001
AI.Min = -0.001
AI.Excit.Val = 2
PhysicalChanName = cDAQ1Mod6/ai7
AI.Bridge.ShuntCal.GainAdjust = 1.0045680558691725
[DAQmxTask SignalExpress DAQ Assistant Step]
Channels = SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai0, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai1, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai2, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai3, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai4, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai5, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai6, SignalExpress DAQ Assistant Step/cDAQ1Mod6_ai7
SampQuant.SampMode = Continuous Samples
SampClk.ActiveEdge = Rising
SampQuant.SampPerChan = 794
SampClk.Rate = 794
SampTimingType = Sample Clock
SampClk.src=
Author = daqmx
AllowInteractiveEditing = 0
AllowInteractiveDeletion = 0
</Val>
</String>
<Inputs>
</Inputs>
<Outputs>
<Signal>
<Type>{1D5A593F-270E-434B-8780-C8D630CEDACC}</Type>
<ID>{0D2A2EFC-8F1B-4A9E-B867-F636B5EAEA47}</ID>
<Name>Strain</Name>
<Label>Strain</Label>
<Visible>True</Visible><Channels>
<Signal>
<ID>{DE31C7E4-31FA-47D8-ACCD-2A6D1CF4D8AC}</ID>
<Name>cDAQ1Mod6_ai0</Name>
<Label>cDAQ1Mod6_ai0</Label>
<Visible>True</Visible></Signal>
<Signal>
<ID>{A22520E0-81D2-4061-8871-066660437DAB}</ID>
<Name>cDAQ1Mod6_ai1</Name>
<Label>cDAQ1Mod6_ai1</Label>
<Signal>
<ID>{BD8950A6-2279-49D4-90D9-9154F0276E3A}</ID>
<Name>cDAQ1Mod6_ai2</Name>
<Label>cDAQ1Mod6_ai2</Label>
<Signal>
<ID>{E4DEE655-5739-4293-AB7B-BF35C3804B1A}</ID>
<Name>cDAQ1Mod6_ai3</Name>
<Label>cDAQ1Mod6_ai3</Label>
<Signal>
<ID>{BC9F91DB-59B6-4BCD-A4AE-B1D7E92CE082}</ID>
<Name>cDAQ1Mod6_ai4</Name>
<Label>cDAQ1Mod6_ai4</Label>
<Signal>
<ID>{5CF175AA-6C71-4027-B462-5EA992153F41}</ID>
<Name>cDAQ1Mod6_ai5</Name>
<Label>cDAQ1Mod6_ai5</Label>
<Signal>
<ID>{9A84BEBB-56E5-45A3-AD07-AEF1347E48C5}</ID>
<Name>cDAQ1Mod6_ai6</Name>
<Label>cDAQ1Mod6_ai6</Label>
<Signal>
<ID>{F0CBD8FC-40E1-407B-9408-C280B8FDE353}</ID>
<Name>cDAQ1Mod6_ai7</Name>
<Label>cDAQ1Mod6_ai7</Label>
</Channels>
</Signal>
</Outputs>
<BoundParameters>
</BoundParameters>
</Step>
</Steps>
<SessionItems><SessionItem>
<Type>{297BE9A4-D56A-4478-83AB-4CA1467995BC}</Type>
<ID>{487BC14B-1449-4B5B-BB17-1AC1D30C0C57}</ID>
</SessionItem>
<SessionItem>
<Type>{422E1286-6E8C-41D2-ADFD-5CB374E1634C}</Type>
<ID>{E6C5C965-4767-4199-897E-3FD95363029F}</ID>
</SessionItem>
<SessionItem>
<Type>{791454E5-F36E-4C3B-86AC-389CBA667774}</Type>
<ID>{EA150EB3-3A64-40E6-9FF6-9ACE80AE6640}</ID>
</SessionItem>
<SessionItem>
<Type>{E3DBE8FB-EC97-4B03-BB0A-593B99B4BC71}</Type>
<ID>{FEDFB7BB-87AE-4D32-84E3-CF2B900656A8}</ID>
</SessionItem>
<SessionItem>
<Type>{F584C2B1-ABA1-4792-A8AA-E3B0B00DB49A}</Type>
<ID>{8BC16F0F-5D2E-4C79-8C95-9D1F62661347}</ID>
</SessionItem>
</SessionItems>
<Type>{55C03B07-81D0-44FD-8C65-4096CFED3A5B}</Type>
<ID>{24DB7F7E-F479-40F6-AF63-F9014E426298}</ID>
<Name>Event Log</Name>
</Tool>
<Tool>
<ID>{FAEF8633-19C9-4F74-990E-84F909B49AD6}</ID>
</Tool>
<Tool>
<Type>{83184E3D-4EF5-4FEC-9D7C-E650CCFF3C12}</Type>
<ID>{A92CFAB6-0597-4210-8B3C-6971379458CF}</ID>
<Name>Log Channel View</Name>
</Tool>
<Tool>
<ID>{E1C823D1-65A8-4EF6-92BF-4215F0E7DA55}</ID>
</Tool>
<Tool>
<ID>{9C3EF713-0917-40AD-B2E8-E889CD4B1E8F}</ID>
</Tool>
<Tool>
<ID>{3EA49C01-9ECF-4AEE-829B-8BA2F0B9F60B}</ID>
</Tool>
<Tool>
<ID>{A6D9DC23-538A-4AD2-A7C1-89AD7481AB78}</ID>
</Tool>
<Tool>
<ID>{5B3F94B8-96DA-4562-858D-9E451F1B9497}</ID>
</Tool>
<Tool>
<ID>{90208E7B-A919-4463-9674-610E6F93E245}</ID>
</Tool>
<Tool>
<ID>{E4119656-B904-4AB0-B067-A9EC2529F0BE}</ID>
</Tool>
<Tool>
<ID>{3DB515D7-6CFB-4D20-884F-A1BC47EDD628}</ID>
</Tool>
<Tool>
<ID>{10ECF147-3FB4-4D1E-B37E-6C9A8D8B438C}</ID>
</Tool>
<Tool>
<ID>{A33864A7-D7D3-4BD3-8D4A-B1897EFFE5F3}</ID>
</Tool>
<Tool>
<ID>{58417D9F-762A-4F81-937D-E18A38E281B3}</ID>
</Tool>
<Tool>
<ID>{E52394A7-EBF7-49E7-9216-6D1E44C41E6F}</ID>
</Tool>
<Tool>
<ID>{2891DD5C-9D3B-40F2-96AC-960FBA23B135}</ID>
</Tool>
<Tool>
<ID>{7DAF86B6-8EAA-4F50-BDA1-4E2ABA62791D}</ID>
</Tool>
<Tool>
<ID>{D3E7D555-0E10-4C4B-8B33-9DDCB6EB058E}</ID>
</Tool>
<Tool>
<ID>{1AF336D8-6EC4-45B1-A895-21A32E7C8EED}</ID>
</Tool>
<Tool>
<ID>{B1498ED6-465B-4782-9C5C-F69F78A3B413}</ID>
</Tool>
<Tool>
<ID>{49E32C1A-64F5-401A-911B-3568E6C76128}</ID>
</Tool>
<Tool>
<ID>{B6AE4DBB-5EF4-47A8-94A1-A34F2CDD5F63}</ID>
</Tool>
<Tool>
<ID>{90E37D1F-2A96-4561-8F7E-2EBCCDF675C5}</ID>
</Tool>
<Tool>
<Type>{937E5DC5-129C-41E1-B21B-78F628634E37}</Type>
<ID>{F5E2E69A-A94F-4B3C-9A8D-68E590A1E324}</ID>
<Name>Recording Options</Name>
</Tool>
<Tool>
<Type>{BFD1A7C1-8AC6-4D4E-87C7-5A379797A8BD}</Type>
<ID>{ACEAE4BA-26AE-4F21-9BCA-025042EAC7B5}</ID>
<Name>Channel View</Name>
</Tool>
<Tool>
<Type>{C3D63DCA-4D18-46A2-91E2-AA87B2B92073}</Type>
<ID>{D5A4B177-1171-46B4-BFD9-251BDE40E91F}</ID>
<Name>Data View</Name>
</Tool>
</ProjectTools>
</WorkArea>
<WorkArea>
<ID>{E7BB99DD-E984-4878-9BCF-8A49F9C1FED1}</ID>
<Name>Playback</Name>
<Description>Use this work area to perform playback and analysis of logs.</Description>
<ProcessesLoggedData>True</ProcessesLoggedData>
<Steps>
</Steps>
<ID>{C930C8C0-0A8B-49B5-B0AA-81CDF9852C01}</ID>
</SessionItem>
</SessionItems>
<Type>{2088C9D9-5FCE-480E-88CC-A89D776BAD35}</Type>
<ID>{DECB1867-4E24-41BE-8B57-A50DCFCAB5B8}</ID>
<Name>Playback Options</Name>
</Tool>
<Tool>
<ID>{D519F63E-13F1-42EA-9EC8-F99499EEAC23}</ID>
</Tool>
<Tool>
<ID>{5ED3D11E-AED2-4FD5-BB04-6E470B2008B8}</ID>
</Tool>
<Tool>
<ID>{8B8CB5C0-641E-4A51-B982-C18ECD0DF5B1}</ID>
</Tool>
</ProjectTools>
</WorkArea>
</WorkAreas>
</ProjectParameters>
(4,117 Views)
