SignalExpress
Custom Scaling using Logarithmic Scale
I am using Cosa dew point sensors to monitor the moisture on an analysis in units of PPMv.  I was told the problem with sensitivity that I was seeing was due from this being a logarithmic scale.  I had both units scaled incorrectly.  Is there a way to create a custom logarithmic scale.  I see the linear, mapped ranges, table, etc but nothing about logarithmic in the create a custom scale area.
Thank you in advance for you help with this.
Brandi
(6,101 Views)
Using SignalExpress, have you tried the Formula step? (Add Step»Processing»Formula). Several Log functions are available using Formula (see link below). Additionally, you can format scales/grids on graph and chart displays by clicking the Properties button on the Data View tab, then selecting the Scales tab. Here you can place a checkmark on Log to map the scale logarithmically. Removing the checkmark from this checkbox will map the scale linearly.
1. LabVIEW SignalExpress 2009 Help: Formula: http://zone.ni.com/reference/en-XX/help/371268K-01/expresswb/formula__scalar/
Ali M
Message Edited by Ali M on 05-04-2010 01:46 PM
(6,082 Views)
