SignalExpress
Can I use Signal Express for multiple customers for only the one time $699?
How do I go about distributing Signal Expresss applications to multiple customers?
(6,940 Views)
Hi Nutter,
Unlike LabVIEW, Signal Express doesn’t have any file distribution capabilities.  If your application uses only basic features, you could install the free LE version of Signal Express on as many computers as necessary.  If you need the full capabilities of Signal Express, however, you would need to purchase a license for each customer.
An alternative to paying for Signal Express for each customer deployment would be to generate LabVIEW code from the Signal Express project and create an executable.  This process is described in the Knowledge Base articles Generate LabVIEW VIs from Signal Express and Deploying VIs generated in Signal Express.  Note that this method requires that you have LabVIEW installed on your development computer with Application Builder capabilities.
Message Edited by Luke G on 05-02-2007 12:23 PM
Luke
Applications Engineer
(6,929 Views)
Hi Luke (or other AE/FE), We have a similar question. Having just purchased the NU USB 9162 w/the 9215 DAQ module we are considering purchasing the Signal Express software. We are running SE now in the evaluation mode, i.e. with all features enabled, and understand that it will revert to SE LE after 30 days. The USB DAQ tools were purchased for use both as a lab tool and as a tool for working at customer stites. As there are more than one potential user at our facility will we, as a customer, be able to install SE on more than one computer in our facility? Thanks. jvjvector
(6,524 Views)
It seems to me from the previous post that you only can use a license per customer. You also have a very good suggestion on how to run LabVIEW code. The best place to find the answer for your question would be contacting: Sales.
Jaime Hoffiz
Product Expert
(6,508 Views)
