 MHR
			MHR
			04-18-2007 04:09 AM
04-19-2007 05:53 AM
04-19-2007 11:14 AM
Hi Way S
We are using the 5671 and are trying to measure squelch hysteresis, but with the dropout we are not able to do the this. We know the UUT has about 2dB of Hysteresis we measured using a conventional sig gen, but with this one to dropout (20mS) causes the squelch to release and then only opens at the cut in point thus giving the effect of no hysteresis.
We have a number of issues related to the no seamless transfer of data where we have had to use a GPIB controlled Sig Gen as an alternative.
Any help would be much appreciated
Thenk Mike (MHR)
04-23-2007 05:58 AM
 perj
			perj
			10-16-2009 01:53 AM
10-16-2009 02:45 AM
Hi Way S
Thanks, I was aware that there was an example in the 8.6 version, we are still running 8.2, but are in the process of changing to 2009. I will give it a try then.
Thanks again
Mike
 perj
			perj
			10-16-2009 03:24 AM
I don't think this is depending on the LabVIEW version. Attached is the VI in 8.2 version. If it's not working, I beleive the problem may be an outdated RFSG driver.
Hope this might help someone, as I have spent some time myself on this problem. Btw, the VI was given me be an engineer from NI named Jan Heinonen.
Per Jørgensen
Test Designer
 GovBob
			GovBob
			10-16-2009 01:54 PM
10-19-2009 02:56 AM
Thanks Per
I will give this one a try, there are many VI's that I have written that will be able to make use of it and speed-up testing, as we will no longer have to wait for the UUT to restabilised after carrier interuption.
Best regards
MHR
