Signal Generators
How to communicate my application trough TCP/IP to a Signal Generator
I have Legacy Software that communicated to a Function Generator trough an RS-232 Cable, and then the Function Generator communicated to a PC trough Ethernet, and then the PC communicated to the Legacy Software.
Now, I need to communicate to the Function Generator trough an ethernet cable, therefore, I will be having TCP/IP both ways. To the Function Generator and the PC.
I have posted the VI for some feedback, if you take a look at
1 GO STATE
1 PROCESS
STATE MACHINE
1 FUNCTION GENERATOR SETUP
you will see how it was set up before,
And on
1 GO STATE
1 PROCESS
STATE MACHINE
2 AGC RETRIEVAL
the way it was received from the PC
thanks.
LabVIEW Intermediate I level!
Message 1 of 29
(8,720 Views)
Hi Bebeto,
I took a look at the VI you posted; it was missing a few subvis. Are you having trouble transitioning to TCP/IP? Are you getting errors? There are good examples of TCP/IP communication in the LabVIEW example finder if you are having trouble getting started.
Matt
Message 2 of 29
(8,695 Views)
Hello Matt,
 I want to be able to communicate to a Signal Generator trough TCP/IP and send out a command to set up the frequency. I have attached the missing VIs to see if you can have a better picture of what I am trying to do.
I have started modifying the code and basically I replaced the VISA for a TCP/IP VI the one I have attached. Please let me know if my logic is correct.
Message 3 of 29
(8,692 Views)
Hi Bebeto,
I looked at you code a little bit and nothing leaps out as being incorrect. I didn’t go too far into it however; I’d rather help you if you’re having problems than review code. Let us know how it progresses.
Matt
Message 4 of 29
(8,671 Views)
Hello Matt,
Actually nothing is wrong with it, it is supposed to communicate to a function generator trough an RS-232 cable. However, and this is where I need help! I am connecting this same code to a function generator using a ETHERNET cable. I went to the NI website and downloaded the drivers needed to communicate to an Agilent N5181A.
I just need to see if you have an example on how to set up a TCP/IP connection  to an  Agilent N5181A.
Message 5 of 29
(8,665 Views)
The driver is already setup for Ethernet communication since it uses VISA. Do NOT change to TCP/IP functions. That would be silly. Go to MAX and follow the instructions for adding a connection to an Ethernet instrument.
Message 6 of 29
(8,663 Views)
Hello Dennis,
Two questions:
Can you please let me know where can I find MAX? Also do I need to add the VISA Run time engine when creating the installer?
Message 7 of 29
(8,659 Views)
MAX is Measurement and Automation Explorer.
If your application uses NI-VISA then you should include NI-VISA in the installer unless you don't want the app to work.Smiley Wink
Message 8 of 29
(8,651 Views)
I don't seem to have it, does it come with the full installation package?
and about VISA the thing is... do I need to include VISA or Agilent drivers have it embedded?
Anyway thanks for your prompt reply
Message 9 of 29
(8,647 Views)
If you installed any NI hardware driver, it will be installed and on your desktop. Otherwise, it's on the driver DVD.
I don't understand your second question at all. What 'embedded' are you talking about?
Message 10 of 29
(8,643 Views)
