Signal Generators
RF Synchronization Suite
Hello! 😄 I’m currently trying the sample codes included in the RF Synchronization Suite. However, I’m having a hard time understanding the effect of the “phase offset” on the IQ data which I generate (or acquire).
For the generation part, I’m testing the sample code named “PXIe-5673 Phase Coherent Arb Waveform Generation with NI-TClk Example”. If for example, I entered 0° as my phase offset for channel 1 and then entered 10° as my phase offset for channel 2, does that mean that my data for channel 1 is AMPLITUDE1∠0° and my data for channel 2 is AMPLITUDE2∠10° in polar form? If so, do I enter these values before running the code, or while running the code (and after which I click the “Update Phase Offsets” button)?
Thank you very much for your time! God Bless! 😄
(6,233 Views)
The answer to this forum post can be found at:
http://forums.ni.com/t5/RF-Measurement-Devices/RF-Synchronization-Suite/m-p/1828839
<Joel Khan | Applications Engineering | National Instruments | Rice University BSEE>
(6,204 Views)
If the link in my previous post fails try the link below.
(6,194 Views)
