Signal Generators
NI-PCI-5401 fault
I am told that the card gives no output It can be seen by the MAX software and it passes the self test function. Any help on the cause of failure would be grateful.
(5,879 Views)
Duplicated Post - Please refer to this thread.
MessyBeast,
Please avoid duplicating posts in this manner.
Christian Hartshorne
NIUK
(5,865 Views)
Unfortunately,this was a fault with your system as on the first two attempts of trying to post, the system crashed (stated that the post had not been submitted). It was only on the third attempt that my entry was successful.
After the third attempt, I went into my account to see the one post which had been accepted. However, I noticed that there were two posts with exactly the same header and info.
I tried to delete the duplicate entry but was unable to find any information on how to do this. Therefore, the duplicate entry had to stand.
Please could you help with the deletion of the duplicate post.
(5,862 Views)
It is not necessary that the post be deleted.
NIUK
(5,828 Views)
