Signal Generators
NI-PCI-5401 fault
I am told that the card gives no output It can be seen by the MAX software and it passes the self test function. Any help on this would be gratefully appreciated.
(6,106 Views)
Hi there!
Could you possibly provide me with some more information please:
What has been used to determine the board has a fault?
What are you trying to measure, or at least the signal type?
Have you tried using the Test Panels in MAX to bring up a test screen?
What are you running with the signal i.e. LabVIEW, LabWindows etc.?
Many thanks!
Liam A.
Applications Engineer
(6,096 Views)
I am told that the card gives no output, which I believe to be a 1kHz Square Wave
The signal is run from an in-house programme which, I believe runs from LabVIEW.
Hope that helps.
(6,092 Views)
Hello again!
The button next to the Self-Test button in MAX is labelled Test Panel. Selecting this will bring up the Test Panel window. If you input the relevent information for the card such as Device, expected Max and min and setting the Mode to "On Demand" then you will be able to test for any output signal by pressing "Play".
This will help determine whereabouts the fault may be occuring.
If you could try this and let me know how you get on that would be great!
Liam A.
(6,086 Views)
Hello again!
Liam A.
(6,086 Views)
