Signal Generators
Help with waveform generation
I have 2 waveforms and I’m trying to add one after another, (like an analogy of concatenation of characters).
I was thinking to make a time offset of one waveform and then add them, but it didn’t work well.
I would appreciate some ideas.
I annex a picture of my VI
undefined
(5,792 Views)
Accepted by topic author lionhikary
The waveform data type is basically just a cluster of 3 pieces of data: 1. the actually data array (Y), 2. the time interval between the points (dt) and 3. the timestamp (t0) that was generated at the begining of the acquisition. The build array function won't let you concatenate the waveforms because it doesn't know if it should use the timestamp from the first waveform or the timestamp from the second. You will need to break each waveform down to its components, concatenate the data arrays, and insert this data into a new waveform with the desired timestamp that you want to use. It should look something like this:
undefined
Jeremy P.
Applications Engineer
(5,782 Views)
Jeremy
Your explanation is very clear and right to the point.
now knowing exactly how waveforms works, it is more easy for me to manipulate them.
(5,777 Views)
