Signal Generators
Fgen_Sweep_Generator reading frequency
Using a ni5402 signal generator and the niFgen_Sweep_Generator_Example.vi.
How can I read/display the actual frequency that is being outputed whilst the signal generator is ramping?
(6,666 Views)
Hi Steve,
Sorry for the long delay in anyone getting back to your post. I've looked into the problem and attempted to find a way to read back the data on the signal generator, unfortunately without any luck. I think the easiest way to read & display the actual frequency would actually be by physically reading the output of the signal generator back into LabVIEW via a signal acquisition card.
Sorry for not being able to find an alternative solution to the problem.
Imtiaz Chowdhury
Project Manager
Green Running / Austin Consultants
(6,558 Views)
It seems this sig generator is not very user friendly in this matter.
I tried a aquiring the frequency via a NI 4070 DMM but found that that was too slow as it took over a second to measure the frequency and as I was ramping at 20Hz/S meant that the result was always 20Hz out, and I also needed faster ramp rates which meant even more error.
The next method was to use the standard frequency function and incremented the frequency in a loop. This also had problems as the standard function switches the output on and off in each loop causing glitches in the output which causes instability.
I also noted that switching between standard function & sweep function also gives glitches.
The final method I found which works best is estimate the frequency as it ramps. As soon as the sweep function starts within LabView you can start a 'for loop' counting the frequency in steps of 1 Hz or so, with a loop wait time equivalent to the ramp time/number of steps. Then passing the estimated frequency out of the loop via a global variable which can be read elsewhere.
(6,536 Views)
Hi Steve,
Unfortunately, it does seem like there is no easy and "proper" way to do this, because of the components that make up the VI - they were created with the intention of only having one output sink. I believe the improvised method you are using with a for loop is a good way to attemp getting around the issue.
Imtiaz Chowdhury
Project Manager
(6,530 Views)
