Signal Conditioning
correct lab view set up for strain aquistion
I am trying to set up strain aquistion for seven independent quarter bridge strain guages using cDAQ 9237 modules and the 9945 bridge completion accesory. However, I will not be able to receive the modules for one month. in the mean time I want to write the aquistion program using lab view 8.2.
I have used an example program for continuous aquistion as a baseline and simply added a task and the physical channels.  I don't have a way to test it. So, I was hoping a user with experience in this area could advise if the set up is fucitonal. currently, I am using virtual devices in order to imput tasks and channels.
thank you
A. Lopez
(4,711 Views)
lopez,
Your code looks great as long it is what you want it to do.
Abhinav T
Applications Engineer
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(4,700 Views)
Hello
I need some guidance and suggestion for my work.
Firstly, I am pretty new with lab view and DAQ system. Somehow, I am studying the data avaialble at NI websites to understand LAB View, DAQ & Strain gauges and have couple of questions.
 I have a specimen which has to be tested for compression load. The specimen is installed with minimum 4 and may be 6 strain gauges.
I need to make a circuit to measure strain individually for these 6 different gauges and need to acquire the data using NI- DAQ max (PXI-1042) system.
I am kind a confuse to understand how many wheat stone bridge circuit do i need to have to measure strain from these 6 different gauges.
Will these circuit be quarterbridge or half bridge or fullbridge to measure strain at 6 different locations?
I will appreciate your input.
Please suggest.
Ankush
(3,871 Views)
Hello Ankush,
That project was back in 2006.    I don't remember to much about it. Would need to start diging though notes.
I have a Compaque DAQ card set up, which is very easy to use with strain guages.  Lab view code also provides an option for selecting half or full bridge. I belive your type of strain guage will dictacte which you choose.
you can contact me directly at alfonso.lopez@hexcel.com if you need to.
good luck.
A. Lopez
(3,860 Views)
Hello Lopez.
Thanks a lot for your help.
I am still  trying to figure it out. i am thinking to make 4 quarter bridge for 4 strain gauges on a breadboard and connecting to Ni-DAq system.
I may need your help for lab view program.  I would write you a mail.
Ankush
(3,849 Views)
