Signal Conditioning
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Parallel and multiplex
I have a PXI-6289 DAQ card installed in a PXI/SCXI combo chassis.
I want to use this to control two SCXI-1125 in parallel mode in a different chassis (SCXI-1001 chassis) and in the same time
to control 3 SCXI-1166s in the combo chassis in multiplexing mode.
Will this setup work?
Rg
Naushad
Message 1 of 9
(7,030 Views)
No, a DAQ card can be configured to acquire from SCXI modules in either parallel or multiplexed mode.
But not both modes at same time
Message 2 of 9
(7,021 Views)
In parallel mode it works out to be one DAQ device per Module you are communicating with. Thats the trade off and why multiplex mode is a good option to go for if true simultaneous sampling is not required.
Message 3 of 9
(7,006 Views)
yes. This was what i heard from the NI engineers.
But it seems my set up works fine.
It acquires signals from SCXI-1125 in parallel mode which are in SCXI-1001,
and at the same time can control the switch modules  in PXI-1052 chassis.
Can you tell me why this works?
Do you see any problems with operation in this set-up?
Rg.
Naushad
Message 4 of 9
(6,996 Views)
I remember reading that SCXI switch modules are controlled by using DIO lines of your DAQ card in a multiplexed mode
Some DIO lines on DAQ card will be reserved for this purpose
I could not find the relevant documentation
If anybody has any support mateial for this, can you please post it??
Message 5 of 9
(6,987 Views)
Is this what you are looking for?
http://digital.ni.com/public.nsf/websearch/86C493E0768EBCFE86256FD4006BCD52?OpenDocument
Cheers
Stuart
Message 6 of 9
(6,981 Views)
The PXI-6289 should be able to control both the 1166's in the PXI/SCXI combo chassis and both the 1125's in parallel mode.  This KB explains you can control both cards using serial communication through the backplane and a card in parallel.  In this case, because the PXI-6289 can control 1125's in parallel mode because it has 16 digital control lines, one through each connector.
I hope that helps!
Micaela N
Message 7 of 9
(6,970 Views)
Stuart,
getting an error message, that particuar page is not found
Message 8 of 9
(6,960 Views)
