 alvamatik
			alvamatik
			03-30-2010 09:29 AM
On my new cRIO-9073 the status led flashes two times, after I (re)installed software on it. The manual says that in this case "the chassis has detected an error in its software [...] Reinstall software on the chassis". I reinstalled three times, each time successfull ("Congratulations..." etc. etc.). In origin there was NI-RIO 3.2 installed on it, but it didn't work with my project (I use Labview 8.6), so I had to reinstall NI-RIO 3.0 and now I think that there's a compatibility problem beetwen the new cRIO-9073 and Labview RT 8.6 (NI-RIO 3.0)
What can I do now?
thanks
03-31-2010 07:29 AM
as you can read in the Software Support for CompactRIO, the minimum version of driver and LabVIEW needed for the cRIO-9073 are LabVIEW 8.6 and NI-RIO 3.0, so you shouldn't have problems of compatibility.
Anyway the NI-RIO are backward compatible with LabVIEW (as stated here), so the system should have worked also with NI-RIO 3.2.
You could have a problem of installation of the software, so you could try the following:
1) format the cRIO and then try again to deploy the software on it
2) uninstall and install again the NI-RIO on your PC and then try to deploy it on the cRIO
Serena
03-31-2010 08:46 AM
How can I format the cRIO ?
Do you mean by "uninstall software" option in MAX? Or by some other method?
03-31-2010 08:52 AM
Have a look at the "Reformatting the Flash Memory Card on a CompactRIO Controller or Single-Board RIO Device" topic in the MAX help for further formatting info.
Serena
03-31-2010 09:34 AM
I formatted flash memory and reinstalled software. Same result.
Now I'll try to reinstall RIO drivers on my computer...
04-01-2010 02:50 AM
I reinstalled NI-RIO 3.0.0 on my computer, then I formatted flash memory and reinstalled software on cRIO-9073, I've got the message "Congratulations! Your LabVIEW Real-Time target has been updated successfully". After reboot, the cRIO is in safe mode, with the message "Software Update Required"
I tried this with different PC and MAX.
Now I think that THERE IS a compatibility problem between new cRIO-9073 and LabVIEW 8.6/NI-RIO 3.0.0
04-01-2010 05:41 AM
this could be a problem with the cRIO or with the updating procedure; so please contact directly the National Instruments Technical Support.
If you are in Italy, yuo can phone to the following number:
02 413091
Serena
04-01-2010 09:29 AM
 Andrew_E
			Andrew_E
			03-08-2011 08:39 AM
