two flashes on cRIO-9073
On my new cRIO-9073 the status led flashes two times, after I (re)installed software on it. The manual says that in this case "the chassis has detected an error in its software [...] Reinstall software on the chassis". I reinstalled three times, each time successfull ("Congratulations..." etc. etc.). In origin there was NI-RIO 3.2 installed on it, but it didn't work with my project (I use Labview 8.6), so I had to reinstall NI-RIO 3.0 and now I think that there's a compatibility problem beetwen the new cRIO-9073 and Labview RT 8.6 (NI-RIO 3.0)
What can I do now?
thanks
Message 1 of 9
(5,301 Views)
as you can read in the Software Support for CompactRIO, the minimum version of driver and LabVIEW needed for the cRIO-9073 are LabVIEW 8.6 and NI-RIO 3.0, so you shouldn't have problems of compatibility.
Anyway the NI-RIO are backward compatible with LabVIEW (as stated here), so the system should have worked also with NI-RIO 3.2.
You could have a problem of installation of the software, so you could try the following:
1) format the cRIO and then try again to deploy the software on it
2) uninstall and install again the NI-RIO on your PC and then try to deploy it on the cRIO
Serena
Message 2 of 9
(5,286 Views)
How can I format the cRIO ?
Do you mean by "uninstall software" option in MAX?  Or by some other method?
Message 3 of 9
(5,279 Views)
Have a look at the "Reformatting the Flash Memory Card on a CompactRIO Controller or Single-Board RIO Device" topic in the MAX help for further formatting info.
Serena
Message 4 of 9
(5,276 Views)
I formatted flash memory and reinstalled software. Same result.
Now I'll try to reinstall RIO drivers on my computer...
Message 5 of 9
(5,273 Views)
I reinstalled NI-RIO 3.0.0 on my computer, then I formatted flash memory and reinstalled software on cRIO-9073, I've got the message "Congratulations! Your LabVIEW Real-Time target has been updated successfully". After reboot, the cRIO is in safe mode, with the message "Software Update Required"
I tried this with different PC and MAX.
Now I think that THERE IS a compatibility problem between new cRIO-9073 and LabVIEW 8.6/NI-RIO 3.0.0
Message 6 of 9
(5,247 Views)
this could be a problem with the cRIO or with the updating procedure; so please contact directly the National Instruments Technical Support.
If you are in Italy, yuo can phone to the following number:
02 413091
Serena
Message 7 of 9
(5,233 Views)
Accepted by alvamatik
this is the console out:
*** Unable to boot.
An old version of NI-RIO is installed on this controller, and it
cannot boot.  You must install NI-RIO 3.1 or greater.
This version of NI-RIO is included with the CD that shipped
with the controller.
the latest cRIO-9073 is NOT compatible with NI-RIO 3.0.0 !!
Message 8 of 9
(5,224 Views)
I think specifically you were experiencing this problem. You have any doubts about compatibility you can check this document.
RIO Embedded Hardware PSE
CompactRIO Developers Guide
Message 9 of 9
(4,574 Views)
