how much difference would it made if previously I use PCI6040E digital trigger, but right now I am using PCI 6036E analog trigger on the same program that has written previously?
Hi tlk20,
There will not be a problem replacing a digital trigger with an analog one. Please make sure to use the correct pin on the 6036, as there are specific pins for AI start and AI reference triggers. The pinouts can be found in the NI-DAQmx Help (Start >> Programs >> National Instruments >> NI-DAQ ). The DAQmx trigger type will also need to be changed from digital to analog.
David L.
Systems Engineering
(3,527 Views)
