05-22-2007 08:32 PM
05-23-2007 12:31 PM
Hi tlk20,
There will not be a problem replacing a digital trigger with an analog one. Please make sure to use the correct pin on the 6036, as there are specific pins for AI start and AI reference triggers. The pinouts can be found in the NI-DAQmx Help (Start >> Programs >> National Instruments >> NI-DAQ ). The DAQmx trigger type will also need to be changed from digital to analog.
06-06-2007 08:11 PM
Thanks, David L.
