02-07-2011 05:18 PM
Detail attached as JPG.
I need to recover from the error.
And I need to know how to set the properties of timer (tick) like example.
Thank You.
02-08-2011 01:08 PM
Did you copy these timed loops over from a real time vi? I ask because they look like real time loops.
Try right clicking on the loop, then replacing it with a timed sequence, then right clicking again an replacing with timed loop. This should look like the attached picture.
Then once you get that, you'll be able to wire in derived clock frequencies. Follow this document on how to create derived clocks in your fpga project:
http://zone.ni.com/reference/en-XX/help/371599F-01/lvfpgahelp/creating_fpga_derived_clk/
