06-11-2019 03:41 PM
I have a cRIO-9045 paired with a cDAQ-9189 for channel expansion. After the initial configuration, the cDAQ shows up in the network devices of the cRIO, however after I restart the cRIO the cDAQ modules show up as "not-present". It's only after I tell the cDAQ to run a self-test and then refresh the cRIO view that the modules show up as present. This manual intervention after every reboot is a hassle. Seems to me the modules should be automatically discovered.
Have other experienced this issue? Could there be a settings issue that would cause this? Any ideas on why and how to fix?
LabVIEW 2018SP1, DAQmx 18.5, cRIO and RIO drivers 18.5.
06-12-2019 05:21 PM
Hello wrkcrw00
This documentation might help you troubleshoot the issues:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7OaSAK&l=en-US
