cRIO with channel expanded cDAQ - modules don't show up on restart
I have a cRIO-9045 paired with a cDAQ-9189 for channel expansion. After the initial configuration, the cDAQ shows up in the network devices of the cRIO, however after I restart the cRIO the cDAQ modules show up as "not-present". It's only after I tell the cDAQ to run a self-test and then refresh the cRIO view that the modules show up as present. This manual intervention after every reboot is a hassle. Seems to me the modules should be automatically discovered.
Have other experienced this issue? Could there be a settings issue that would cause this? Any ideas on why and how to fix?
LabVIEW 2018SP1, DAQmx 18.5, cRIO and RIO drivers 18.5.
(2,019 Views)
Hello wrkcrw00
This documentation might help you troubleshoot the issues:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7OaSAK&l=en-US
(1,989 Views)
