Using MyRIO's Differential Analog Input as a Single Ended Input
Hi
I want to use the MyRIO's Connector C's Differential Analog Input (+-10V) as a single-ended analog input. A related previous post where this was done and resulted in a better signal to noise ratio is found here: https://forums.ni.com/t5/Real-Time-Measurement-and/myRIO-Analog-Inputs-GND-Reference-How-to-mitigate...
My question is: is it sufficient to simply connect the AI- to the MyRIO's signal ground, and connect the single ended output from the sensor I am measuring from at the AI+, or does the channel have to be configured in the MyRIO specifically for use as a single input channel?
I see for the following cRIO module, there is a configuration option: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAjRSAW
However I was unable to find any such configuration option in the LabVIEW project for the MyRIO
Any thoughts?
(4,470 Views)
Yes, you have the basic idea down. It's not unusual though to send a differential pair out from the + and - input all the way to the sensor. It can seem like redundant wiring but it can help cancel certain forms of noise.
This guide has a picture showing you where in the project to configure the endedness https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P906SAC
(4,449 Views)
Accepted by ghp_1
Hi
Thank you for these details
The guide however is for the cRIO, and not the MyRIO. I tried looking in the project tree and couldn't find any such option for the MyRIO
Perhaps the MyRIO doesn't have such an option?
(4,426 Views)
Ahh, yeah, I didn't notice that you were on MyRIO. MyRIO isn't configurable. The behavior (differential vs single ended) is fixed per pin. Check out page 8 here:
http://www.ni.com/pdf/manuals/376047c.pdf
(4,419 Views)
But in general you and nanocyte are correct. If your sensor does only have a single-ended output but your input is differential, you should wire the sensors ground-reference (probably common ground or your power supply's "Minus") to the input channel's Minus.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(4,406 Views)
